树莓派 Pico 2 W 无线接入点(物联网 LED 控制方案)
本文将介绍如何基于 C 语言软件开发工具包(C SDK),将树莓派 Pico 2 W 配置为无线接入点(局域网热点),其无线通信遵循2.4GHz IEEE 802.11n 标准。该设备内置动态主机配置协议(DHCP)服务器,可为直连客户端分配 IP 地址,功能与 WiFi 路由器类似。
前提条件:电脑端已正确安装树莓派 Pico C SDK 开发环境。
第一步,编译以下 C 语言源代码:
 * Copyright (c) 2022 Raspberry Pi (Trading) Ltd.
 * SPDX-License-Identifier: BSD-3-Clause
#include <string.h>
#include "pico/cyw43_arch.h"
#include "pico/stdlib.h"
#include "lwip/pbuf.h"
#include "lwip/tcp.h"
#include "dhcpserver.h"
#include "dnsserver.h"
#define TCP_PORT 80
#define DEBUG_printf printf
#define POLL_TIME_S 5
#define HTTP_GET "GET"
#define HTTP_RESPONSE_HEADERS "HTTP/1.1 %d OK\nContent-Length: %d\nContent-Type: text/html; charset=utf-8\nConnection: close\n\n"
#define LED_TEST_BODY "<html><body><h1>Hello from Pico.</h1><p>Led is %s</p><p><a href=\"?led=%d\">Turn led %s</a></body></html>"
#define LED_PARAM "led=%d"
#define LED_TEST "/ledtest"
#define LED_GPIO 0
#define HTTP_RESPONSE_REDIRECT "HTTP/1.1 302 Redirect\nLocation: http://%s" LED_TEST "\n\n"
typedef struct TCP_SERVER_T_ {
    struct tcp_pcb *server_pcb;
    bool complete;
    ip_addr_t gw;
} TCP_SERVER_T;
typedef struct TCP_CONNECT_STATE_T_ {
    struct tcp_pcb *pcb;
    int sent_len;
    char headers[128];
    char result[256];
    int header_len;
    int result_len;
    ip_addr_t *gw;
} TCP_CONNECT_STATE_T;
static err_t tcp_close_client_connection(TCP_CONNECT_STATE_T *con_state, struct tcp_pcb *client_pcb, err_t close_err) {
    if (client_pcb) {
        assert(con_state && con_state->pcb == client_pcb);
        tcp_arg(client_pcb, NULL);
        tcp_poll(client_pcb, NULL, 0);
        tcp_sent(client_pcb, NULL);
        tcp_recv(client_pcb, NULL);
        tcp_err(client_pcb, NULL);
        err_t err = tcp_close(client_pcb);
        if (err != ERR_OK) {
            DEBUG_printf("close failed %d, calling abort\n", err);
            tcp_abort(client_pcb);
            close_err = ERR_ABRT;
        if (con_state) {
            free(con_state);
    return close_err;
static void tcp_server_close(TCP_SERVER_T *state) {
    if (state->server_pcb) {
        tcp_arg(state->server_pcb, NULL);
        tcp_close(state->server_pcb);
        state->server_pcb = NULL;
static err_t tcp_server_sent(void *arg, struct tcp_pcb *pcb, u16_t len) {
    TCP_CONNECT_STATE_T *con_state = (TCP_CONNECT_STATE_T*)arg;
    DEBUG_printf("tcp_server_sent %u\n", len);
    con_state->sent_len += len;
    if (con_state->sent_len >= con_state->header_len + con_state->result_len) {
        DEBUG_printf("all done\n");
        return tcp_close_client_connection(con_state, pcb, ERR_OK);
    return ERR_OK;
static int test_server_content(const char *request, const char *params, char *result, size_t max_result_len) {
    int len = 0;
    if (strncmp(request, LED_TEST, sizeof(LED_TEST) - 1) == 0) {
        // Get the state of the led
        bool value;
        cyw43_gpio_get(&cyw43_state, LED_GPIO, &value);
        int led_state = value;
        // See if the user changed it
        if (params) {
            int led_param = sscanf(params, LED_PARAM, &led_state);
            if (led_param == 1) {
                if (led_state) {
                    // Turn led on
                    cyw43_gpio_set(&cyw43_state, LED_GPIO, true);
                } else {
                    // Turn led off
                    cyw43_gpio_set(&cyw43_state, LED_GPIO, false);
        // Generate result
        if (led_state) {
            len = snprintf(result, max_result_len, LED_TEST_BODY, "ON", 0, "OFF");
        } else {
            len = snprintf(result, max_result_len, LED_TEST_BODY, "OFF", 1, "ON");
    return len;
err_t tcp_server_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err) {
    if (!p) {
        DEBUG_printf("connection closed\n");
    assert(con_state && con_state->pcb == pcb);
    if (p->tot_len > 0) {
        DEBUG_printf("tcp_server_recv %d err %d\n", p->tot_len, err);
#if 0
        for (struct pbuf *q = p; q != NULL; q = q->next) {
            DEBUG_printf("in: %.*s\n", q->len, q->payload);
#endif
        // Copy the request into the buffer
        pbuf_copy_partial(p, con_state->headers, p->tot_len > sizeof(con_state->headers) - 1 ? sizeof(con_state->headers) - 1 : p->tot_len, 0);
        // Handle GET request
        if (strncmp(HTTP_GET, con_state->headers, sizeof(HTTP_GET) - 1) == 0) {
            char *request = con_state->headers + sizeof(HTTP_GET); // + space
            char *params = strchr(request, '?');
            if (params) {
                if (*params) {
                    char *space = strchr(request, ' ');
                    *params++ = 0;
                    if (space) {
                        *space = 0;
                } else {
                    params = NULL;
            // Generate content
            con_state->result_len = test_server_content(request, params, con_state->result, sizeof(con_state->result));
            DEBUG_printf("Request: %s?%s\n", request, params);
            DEBUG_printf("Result: %d\n", con_state->result_len);
            // Check we had enough buffer space
            if (con_state->result_len > sizeof(con_state->result) - 1) {
                DEBUG_printf("Too much result data %d\n", con_state->result_len);
                return tcp_close_client_connection(con_state, pcb, ERR_CLSD);
            // Generate web page
            if (con_state->result_len > 0) {
                con_state->header_len = snprintf(con_state->headers, sizeof(con_state->headers), HTTP_RESPONSE_HEADERS,
                    200, con_state->result_len);
                if (con_state->header_len > sizeof(con_state->headers) - 1) {
                    DEBUG_printf("Too much header data %d\n", con_state->header_len);
            } else {
                // Send redirect
                con_state->header_len = snprintf(con_state->headers, sizeof(con_state->headers), HTTP_RESPONSE_REDIRECT,
                    ipaddr_ntoa(con_state->gw));
                DEBUG_printf("Sending redirect %s", con_state->headers);
            // Send the headers to the client
            con_state->sent_len = 0;
            err_t err = tcp_write(pcb, con_state->headers, con_state->header_len, 0);
                DEBUG_printf("failed to write header data %d\n", err);
                return tcp_close_client_connection(con_state, pcb, err);
            // Send the body to the client
            if (con_state->result_len) {
                err = tcp_write(pcb, con_state->result, con_state->result_len, 0);
                    DEBUG_printf("failed to write result data %d\n", err);
        tcp_recved(pcb, p->tot_len);
    pbuf_free(p);
    return ERR_OK;
static err_t tcp_server_poll(void *arg, struct tcp_pcb *pcb) {
    DEBUG_printf("tcp_server_poll_fn\n");
    return tcp_close_client_connection(con_state, pcb, ERR_OK); // Just disconnect clent?
static void tcp_server_err(void *arg, err_t err) {
    if (err != ERR_ABRT) {
        DEBUG_printf("tcp_client_err_fn %d\n", err);
        tcp_close_client_connection(con_state, con_state->pcb, err);
static err_t tcp_server_accept(void *arg, struct tcp_pcb *client_pcb, err_t err) {
    TCP_SERVER_T *state = (TCP_SERVER_T*)arg;
    if (err != ERR_OK || client_pcb == NULL) {
        DEBUG_printf("failure in accept\n");
        return ERR_VAL;
    DEBUG_printf("client connected\n");
    // Create the state for the connection
    TCP_CONNECT_STATE_T *con_state = calloc(1, sizeof(TCP_CONNECT_STATE_T));
    if (!con_state) {
        DEBUG_printf("failed to allocate connect state\n");
        return ERR_MEM;
    con_state->pcb = client_pcb; // for checking
    con_state->gw = &state->gw;
    // setup connection to client
    tcp_arg(client_pcb, con_state);
    tcp_sent(client_pcb, tcp_server_sent);
    tcp_recv(client_pcb, tcp_server_recv);
    tcp_poll(client_pcb, tcp_server_poll, POLL_TIME_S * 2);
    tcp_err(client_pcb, tcp_server_err);
    return ERR_OK;
static bool tcp_server_open(void *arg, const char *ap_name) {
    DEBUG_printf("starting server on port %d\n", TCP_PORT);
    struct tcp_pcb *pcb = tcp_new_ip_type(IPADDR_TYPE_ANY);
    if (!pcb) {
        DEBUG_printf("failed to create pcb\n");
        return false;
    err_t err = tcp_bind(pcb, IP_ANY_TYPE, TCP_PORT);
    if (err) {
        DEBUG_printf("failed to bind to port %d\n",TCP_PORT);
        return false;
    state->server_pcb = tcp_listen_with_backlog(pcb, 1);
    if (!state->server_pcb) {
        DEBUG_printf("failed to listen\n");
        if (pcb) {
            tcp_close(pcb);
        return false;
    tcp_arg(state->server_pcb, state);
    tcp_accept(state->server_pcb, tcp_server_accept);
    printf("Try connecting to '%s' (press 'd' to disable access point)\n", ap_name);
    return true;
void key_pressed_func(void *param) {
    assert(param);
    TCP_SERVER_T *state = (TCP_SERVER_T*)param;
    int key = getchar_timeout_us(0); // get any pending key press but don't wait
    if (key == 'd' || key == 'D') {
        cyw43_arch_lwip_begin();
        cyw43_arch_disable_ap_mode();
        cyw43_arch_lwip_end();
        state->complete = true;
int main() {
    stdio_init_all();
    TCP_SERVER_T *state = calloc(1, sizeof(TCP_SERVER_T));
    if (!state) {
        DEBUG_printf("failed to allocate state\n");
        return 1;
    if (cyw43_arch_init()) {
        DEBUG_printf("failed to initialise\n");
        return 1;
    // Get notified if the user presses a key
    stdio_set_chars_available_callback(key_pressed_func, state);
    const char *ap_name = "picow_test";
#if 1
    const char *password = "password";
#else
    const char *password = NULL;
#endif
    cyw43_arch_enable_ap_mode(ap_name, password, CYW43_AUTH_WPA2_AES_PSK);
    #if LWIP_IPV6
    #define IP(x) ((x).u_addr.ip4)
    #else
    #define IP(x) (x)
    #endif
    ip4_addr_t mask;
    IP(state->gw).addr = PP_HTONL(CYW43_DEFAULT_IP_AP_ADDRESS);
    IP(mask).addr = PP_HTONL(CYW43_DEFAULT_IP_MASK);
    #undef IP
    // Start the dhcp server
    dhcp_server_t dhcp_server;
    dhcp_server_init(&dhcp_server, &state->gw, &mask);
    // Start the dns server
    dns_server_t dns_server;
    dns_server_init(&dns_server, &state->gw);
    if (!tcp_server_open(state, ap_name)) {
        DEBUG_printf("failed to open server\n");
        return 1;
    state->complete = false;
    while(!state->complete) {
        // the following #ifdef is only here so this same example can be used in multiple modes;
        // you do not need it in your code
#if PICO_CYW43_ARCH_POLL
        // if you are using pico_cyw43_arch_poll, then you must poll periodically from your
        // main loop (not from a timer interrupt) to check for Wi-Fi driver or lwIP work that needs to be done.
        cyw43_arch_poll();
        // you can poll as often as you like, however if you have nothing else to do you can
        // choose to sleep until either a specified time, or cyw43_arch_poll() has work to do:
        cyw43_arch_wait_for_work_until(make_timeout_time_ms(1000));
#else
        // if you are not using pico_cyw43_arch_poll, then Wi-FI driver and lwIP work
        // is done via interrupt in the background. This sleep is just an example of some (blocking)
        // work you might be doing.
        sleep_ms(1000);
#endif
    tcp_server_close(state);
    dns_server_deinit(&dns_server);
    dhcp_server_deinit(&dhcp_server);
    cyw43_arch_deinit();
    printf("Test complete\n");
    return 0;
编译完成后,该工程会生成一个集成DHCP 服务器HTTP 服务器的固件。其中 DHCP 服务器负责为客户端分配 IP,HTTP 服务器基于面向连接的 TCP 协议工作,用户可通过它控制 树莓派 Pico 2 W 板载绿色 LED 的亮灭。
完成无线接入点工程编译后,将示例固件文件
picow_access_point_background.uf2
按照以下步骤烧录至 树莓派 Pico 2 W 开发板:
digikey_coffee_cup # picotool load picow_access_point_background.uf2
固件烧录完成后,使用电脑、笔记本或手机等终端设备,连接名为 picow_test 的 WiFi 热点,认证信息如下:
login: picow_test
password: password
连接成功后,打开浏览器访问设备:
该网页由 树莓派 Pico 2 W 内置的 HTTP 服务器生成,用户可在页面中查看板载 LED 的当前状态(点亮 / 熄灭),并对其进行远程控制。点击页面中的 Turn led ON 链接,稍作延时后,开发板上的绿色 LED 将会点亮,同时网页会同步更新 LED 状态,如下所示:
重复上述操作,即可直观演示如何通过 HTTP 客户端浏览器,基于 TCP 协议,经由 树莓派 Pico 2 W 自建的无线接入点(功能类似路由器)实现对板载 LED 的远程控制。其他 树莓派 Pico 2 W 设备也可接入该热点,无需依赖传统路由器。本方案中,HTTP 客户端与 Pico 2 W 设备为 WiFi 直连模式。
若需修改热点信息,只需调整代码中对应的热点名称与密码参数即可,示例如下:
const char *ap_name = "picow_test1";
树莓派 Pico 2 W 开发板可通过得捷电子(DigiKey)购买。祝您使用愉快!
SC1633 Raspberry Pi | 开发板,套件,编程器 | DigiKey
