Lattice ICE40 UltraPlus 开发板(SPRAM 功能演示)
本演示基于 Lattice ICE40 UltraPlus FPGA 开发板 开展
旨在通过有限状态机的设计与实现,演示如何借助下文所示的 FPGA 片内 SB_SPRAM256KA 模块,对片内 SPRAM 执行写入操作。
本演示采用了如下 Verilog HDL 代码:
//Digikey Coffee Cup test of the SPRAM, using a state machine to write values in SPRAM, then
//reading them. The values written in memory is different combinations colors of a RGB led
module top(input clk, output LED_R, output LED_G, output LED_B);
  reg [7:0] state;
  reg [31:0] counter;
  //access to spram
  reg [15:0] ram_addr;
  wire [15:0] ram_data_in;
  wire [15:0] ram_data_out;
  wire ram_wren;
  parameter IDLE = 0, INIT0 = IDLE+1, INIT1=INIT0+1, INIT2=INIT1+1, INIT3=INIT2+1, INIT4=INIT3+1, INIT5=INIT4+1, INIT6=INIT5+1, INIT7=INIT6+1, RUN=INIT7+1;
  reg [2:0] led;
  //leds are active low
  assign LED_R = ~led[0];
  assign LED_G = ~led[1];
  assign LED_B = ~led[2];
  SB_SPRAM256KA spram
    .ADDRESS(ram_addr),
    .DATAIN(ram_data_in),
    .MASKWREN({ram_wren, ram_wren, ram_wren, ram_wren}),
    .WREN(ram_wren),
    .CHIPSELECT(1'b1),
    .CLOCK(clk),
    .STANDBY(1'b0),
    .SLEEP(1'b0),
    .POWEROFF(1'b1),
    .DATAOUT(ram_data_out)
  initial begin
      state <= INIT0;
      led <= 3'b000;
      counter <= 0;
  end
  always @(posedge clk)
  begin
    ram_wren <= 1'b0;
    case(state)
		IDLE:
			begin
			end
		INIT0:
			begin
			  ram_addr <= 16'b000;
			  ram_data_in <= 16'b001; //write red
			  ram_wren <= 1'b1;
			  state <= INIT1;
			end
		INIT1:
			begin
			  ram_addr <= 16'b001;
			  ram_data_in <= 16'b010; //write green
			  ram_wren <= 1'b1;
			  state <= INIT2;
			end
		INIT2:
			begin
			  ram_addr <= 16'b010;
			  ram_data_in <= 16'b011; //write yellow
			  ram_wren <= 1'b1;
			  state <= INIT3;
			end
		INIT3:
			begin
			  ram_addr <= 16'b011;
			  ram_data_in <= 16'b100; //write blue
			  ram_wren <= 1'b1;
			  state <= INIT4;
			end
		INIT4:
			begin
			  ram_addr <= 16'b100;
			  ram_data_in <= 16'b101; //write pink
			  ram_wren <= 1'b1;
			  state <= INIT5;
			end
		INIT5:
			begin
			  ram_addr <= 16'b101;
			  ram_data_in <= 16'b110; //write light blue
			  ram_wren <= 1'b1;
			  state <= INIT6;
			end
		INIT6:
			begin
			  ram_addr <= 16'b110;
			  ram_data_in <= 16'b111; //write light pink
			  ram_wren <= 1'b1;
			  state <= INIT7;
			end
		INIT7:
			begin
			  ram_addr <= 16'b111;
			  ram_wren <= 1'b1;
			  state <= RUN;
			end
		RUN:
			begin
			  counter <= counter + 1;
			  //increment address every ~1sec at 12Mhz
			  if(counter == 32'h1000000) begin
				ram_addr[2:0] <= ram_addr[2:0] + 1;
			  end
			  if(counter == 32'h1000002) begin //wait two cycles to have data
				 led <= ram_data_out[2:0];
				 counter <= 0;
			  end
			end
    endcase
  end
endmodule
本演示通过有限状态机完成SPRAM 模块的数据写入与回读操作。写入内存的数据,对应开发板上 RGB LED 的不同颜色组合。写入 SPRAM 模块的颜色数据顺序为:红色、绿色、黄色、蓝色、粉色、浅蓝色、浅粉色、黄色。数据写入完成后,系统从 SPRAM 中读取这些颜色数据,并在开发板的 RGB LED 上循环显示。
相关 SPRAM 模块演示效果可参考下方视频。
Lattice ICE40 UltraPlus FPGA 开发板适用于多种应用场景,可在 DigiKey 平台采购。
