【DigiKey好物畅享】ST NUCLEO-WBA65RI 蓝牙创建-2
代码的添加
STMWBAxx_Nucleo 板级驱动
修改代码
修改代码我也是仿着 demo 来的
app_conf.h
应用功能配置相关,当前我这里CFG_BUTTON_SUPPORTED 设置为 0,CFG_LED_SUPPORTED 设置为 1 此时只会初始化灯相关代码
  /* USER CODE BEGIN CFG_Task_Id_t */
  CFG_TASK_ADV_CANCEL_ID,
  CFG_TASK_SEND_NOTIF_ID,
  /* USER CODE END CFG_Task_Id_t */
/* USER CODE BEGIN Defines */
#define CFG_BSP_ON_SEQUENCER                    (1)
#define CFG_BSP_ON_NUCLEO                       (1)
 * User interaction
 * When CFG_LED_SUPPORTED is set, LEDS are activated if requested
 * When CFG_BUTTON_SUPPORTED is set, the push button are activated if requested
#define CFG_LED_SUPPORTED                       (1)
#define CFG_BUTTON_SUPPORTED                    (0)
 * Overwrite some configuration imposed by Low Power level selected.
#if (CFG_LPM_LEVEL > 1)
  #if CFG_LED_SUPPORTED
    #undef  CFG_LED_SUPPORTED
    #define CFG_LED_SUPPORTED      (0)
  #endif /* CFG_LED_SUPPORTED */
#endif /* CFG_LPM_LEVEL */
/* USER CODE END Defines */
app_entry.c
需要初始化的板级驱动,这里只会初始化 LED
/* USER CODE BEGIN Includes */
#include "app_bsp.h"
/* USER CODE END Includes */
 /* USER CODE BEGIN APPE_Init_1 */
#if (CFG_LED_SUPPORTED == 1)
  APP_BSP_LedInit();
#endif /* (CFG_LED_SUPPORTED == 1) */
#if (CFG_BUTTON_SUPPORTED == 1)
  APP_BSP_ButtonInit();
#endif /* (CFG_BUTTON_SUPPORTED == 1) */
  /* USER CODE END APPE_Init_1 */
